Particle Swarm Optimization Approach for Fuzzy Cognitive Maps Applied to Autism Classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The task of classification using intelligent methods and learning algorithms is a difficult task leading the research community on finding new classifications techniques to solve it. In this work, a new approach based on particle swarm optimization (PSO) clustering is proposed to perform the fuzzy cognitive map learning for classification performance. Fuzzy cognitive map (FCM) is a simple, but also powerful computational intelligent technique which is used for the adoption of the human knowledge and/or historical data, into a simple mathematical model for system modeling and analysis. The aim of this study is to investigate a new classification algorithm for the autism disorder problem by integrating the Particle Swarm Optimization method (PSO) in FCM learning, thus producing a higher performance classification tool regarding the accuracy of the classification, and overcoming the limitations of FCMs in the pattern analysis area.
978-3-642-41142-7_52_Chapter.pdf (262.58 Ko) Télécharger le fichier
hal-01459643 , version 1 (07-02-2017)
Paternité
Panagiotis Oikonomou, Elpiniki I. Papageorgiou. Particle Swarm Optimization Approach for Fuzzy Cognitive Maps Applied to Autism Classification. 9th Artificial Intelligence Applications and Innovations (AIAI), Sep 2013, Paphos, Greece. pp.516-526, ⟨10.1007/978-3-642-41142-7_52⟩. ⟨hal-01459643⟩
49 Consultations
173 Téléchargements
