Real-Time Covert Timing Channel Detection in Networked Virtual Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite extensive research on malware and Trojan horses, covert channels are still among the top computer security threats. These attacks, which are launched using specially-crafted content or by manipulating timing characteristics, transmit sensitive information to adversaries while remaining undetected. Current detection approaches typically analyze deviations from legitimate network traffic statistics. These approaches, however, are not applicable to highly dynamic, noisy environments, such as cloud computing environments, because they rely heavily on historical traffic and tedious model training. To address these challenges, we present a real-time, wavelet-based approach for detecting covert timing channels. The novelty of the approach comes from leveraging a secure virtual machine to mimic a vulnerable virtual machine. A key advantage is that the detection approach does not require historical traffic data. Experimental results demonstrate that the approach exhibits good overall performance, including a high detection rate and a low false positive rate.
978-3-642-41148-9_19_Chapter.pdf (1.73 Mo) Télécharger le fichier
hal-01460611 , version 1 (07-02-2017)
Paternité
Anyi Liu, Jim Chen, Harry Wechsler. Real-Time Covert Timing Channel Detection in Networked Virtual Environments. 9th International Conference on Digital Forensics (DF), Jan 2013, Orlando, FL, United States. pp.273-288, ⟨10.1007/978-3-642-41148-9_19⟩. ⟨hal-01460611⟩
102 Consultations
134 Téléchargements
