On the Scientific Maturity of Digital Forensics Research
This paper applies a scientific maturity grade schema from the software engineering domain to research in the field of digital forensics. On the basis of this maturity schema and its grades, the paper classifies the current maturity of digital forensics research. The findings show that much more research conducted at higher levels of “scientificness” is necessary before the new field of digital forensics can be considered to be scientifically mature.
Informatique [cs]
