On the Scientific Maturity of Digital Forensics Research - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper applies a scientific maturity grade schema from the software engineering domain to research in the field of digital forensics. On the basis of this maturity schema and its grades, the paper classifies the current maturity of digital forensics research. The findings show that much more research conducted at higher levels of “scientificness” is necessary before the new field of digital forensics can be considered to be scientifically mature.
978-3-642-41148-9_3_Chapter.pdf (1.23 Mo) Télécharger le fichier
hal-01460619 , version 1 (07-02-2017)
Paternité
Martin Olivier, Stefan Gruner. On the Scientific Maturity of Digital Forensics Research. 9th International Conference on Digital Forensics (DF), Jan 2013, Orlando, FL, United States. pp.33-49, ⟨10.1007/978-3-642-41148-9_3⟩. ⟨hal-01460619⟩
187 Consultations
118 Téléchargements
