Development of Automatic Assembly Sequence Generating System Based on the New Type of Parts Liaison Graph
Nowadays in order to perform assembly process planning by using CAPP (Computer Aided Process Planning), researches to generate the assembly sequence have come under constant interest by many researchers and they are devoted to optimize the assembly sequence according to the novel approach such as Genetic Algorithm and the newly biology inspired principle such as ant colony optimizing method. In this paper, the developed assembly sequence generating system analyzes the relationship between assembled parts based on surface contacting information. Moreover, this system generates the new type of parts liaison graph for the assembly sequences via analyzed information such as common area between parts, related ratio and number of the connected parts. Finally, the optimized assembly sequence is generated logically through the parts liaison graph.
Informatique [cs]
