Context-Aware Process Modelling through Imperative and Declarative Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olaolu Sofela
  • Fonction : Auteur
  • PersonId : 1000927
Lai Xu
  • Fonction : Auteur
  • PersonId : 992712
Paul De Vrieze
  • Fonction : Auteur
  • PersonId : 992713
Business process models can help to improve process visibility and shared understanding, particularly across internal and external stakeholders. By supporting knowledge transfer and enhancing documentation, they aid compliance and ultimately improve software quality. However, many current process modelling approaches and tools require significant learning on the part of users and resultant models may often be prone to errors. The use of such approaches also demands a certain level of domain expertise in both the business and IT domains. Hence, the need to accommodate a wider user group for business process models, including those, often end users, who are not IT experts. Context-aware process modelling allows end users to identify a business process model from a process repository according to different context information. In this paper, we develop a new approach to help end users for building up potential process models using PVDI (process variability through declarative and imperative). A real world case is used to explain and verify our approach.
978-3-642-40543-3_21_Chapter.pdf (384.5 Ko) Télécharger le fichier
hal-01463209 , version 1 (09-02-2017)
Paternité
Olaolu Sofela, Lai Xu, Paul De Vrieze. Context-Aware Process Modelling through Imperative and Declarative Approach. 14th Working Conference on Virtual Enterprises, (PROVE), Sep 2013, Dresden, Germany. pp.191-200, ⟨10.1007/978-3-642-40543-3_21⟩. ⟨hal-01463209⟩
209 Consultations
65 Téléchargements
