Abstract : This paper studies the specification, mapping and the transforming of behavioral aspects of Open Distributed Processing Information Language, within the context of Model Driven Architecture. In order to specify the executable behavior of a system and to make the processes of the Information executable and controllable, the Reference Model for Open Distributed Processing can be used as a meta-model for behavioral specifications. In the Information language the behavior is specified in terms of schema dynamic, processes, actions, state and the relationships between these concepts. In this work we describe how behavior process can be generated exploiting the benefits of a MDA approach. We define the behavior models by using UML profile and their transformations into BPEL artifacts.
https://hal.inria.fr/hal-01463210 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, February 9, 2017 - 2:31:20 PM Last modification on : Thursday, May 27, 2021 - 10:38:01 AM Long-term archiving on: : Wednesday, May 10, 2017 - 2:00:02 PM
youssef Balouki, Abdessamed Balouki, Mohamed El Far, Abdelouahed Kriouile. Transformation of Models in an MDA Approach for Collaborative Distributed Processes. 14th Working Conference on Virtual Enterprises, (PROVE), Sep 2013, Dresden, Germany. pp.201-208, ⟨10.1007/978-3-642-40543-3_22⟩. ⟨hal-01463210⟩
