Transformation of Models in an MDA Approach for Collaborative Distributed Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Youssef Balouki
  • Fonction : Auteur
  • PersonId : 1000928
Abdessamed Balouki
  • Fonction : Auteur
  • PersonId : 1000929
Mohamed El Far
  • Fonction : Auteur
  • PersonId : 1000930
Abdelouahed Kriouile
  • Fonction : Auteur
  • PersonId : 1000931
This paper studies the specification, mapping and the transforming of behavioral aspects of Open Distributed Processing Information Language, within the context of Model Driven Architecture. In order to specify the executable behavior of a system and to make the processes of the Information executable and controllable, the Reference Model for Open Distributed Processing can be used as a meta-model for behavioral specifications. In the Information language the behavior is specified in terms of schema dynamic, processes, actions, state and the relationships between these concepts. In this work we describe how behavior process can be generated exploiting the benefits of a MDA approach. We define the behavior models by using UML profile and their transformations into BPEL artifacts.
978-3-642-40543-3_22_Chapter.pdf (65.04 Ko) Télécharger le fichier
hal-01463210 , version 1 (09-02-2017)
Paternité
Youssef Balouki, Abdessamed Balouki, Mohamed El Far, Abdelouahed Kriouile. Transformation of Models in an MDA Approach for Collaborative Distributed Processes. 14th Working Conference on Virtual Enterprises, (PROVE), Sep 2013, Dresden, Germany. pp.201-208, ⟨10.1007/978-3-642-40543-3_22⟩. ⟨hal-01463210⟩
61 Consultations
88 Téléchargements
