From Service Design to Innovation through Services: Emergence of a Methodological and Systemic Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Florie Bugeaud
  • Fonction : Auteur
  • PersonId : 1000964
Paul Pietyra
  • Fonction : Auteur
  • PersonId : 1000965
Victor Liger
  • Fonction : Auteur
  • PersonId : 1000966
The current crisis conducts companies to seek new solutions for growth. In this context, the still new field of Service Design (SD) is gaining more and more attention. Easy to use and based on collaborative processes, it enables to achieve quite quick results. However the SD process is mastered by few actors inside organizations. There is a need to scale up the process to the whole organization. To achieve that goal, SD needs to undergo an industrialization process. What’s more, doing SD projects is not enough to change a company. SD has to be linked to transformation strategies. This paper introduces a dedicated framework which is based on four basic components all along the Service Design process: Knowledge, Software tools, Communities and Places. The paper mainly focuses on the first two components. It will be illustrated with a complete demonstration during the session.
978-3-642-40543-3_46_Chapter.pdf (1.51 Mo) Télécharger le fichier
hal-01463236 , version 1 (09-02-2017)
Paternité
Florie Bugeaud, Paul Pietyra, Victor Liger. From Service Design to Innovation through Services: Emergence of a Methodological and Systemic Framework. 14th Working Conference on Virtual Enterprises, (PROVE), Sep 2013, Dresden, Germany. pp.431-438, ⟨10.1007/978-3-642-40543-3_46⟩. ⟨hal-01463236⟩
168 Consultations
133 Téléchargements
