Promoting Remanufacturing through Collaboration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Iris Karvonen
  • Fonction : Auteur
  • PersonId : 1000979
Kim Jansson
  • Fonction : Auteur
  • PersonId : 1000980
Mikko Uoti
  • Fonction : Auteur
  • PersonId : 1000981
Remanufacturing is an ultimate form of recycling by manufacturing “good as new” products from used products. Through remanufacturing, materials and energy can be saved and less waste is produced. However, at present, the application of remanufacturing is common only in specific industrial fields and geographic areas. This paper describes challenges identified and discusses how collaboration and networking of companies can support the implementation of remanufacturing. In addition to cases described in literature, the study uses information collected from Finnish case companies operating in remanufacturing.
978-3-642-40543-3_63_Chapter.pdf (97.05 Ko) Télécharger le fichier
hal-01463255 , version 1 (09-02-2017)
Paternité
Iris Karvonen, Kim Jansson, Mikko Uoti. Promoting Remanufacturing through Collaboration. 14th Working Conference on Virtual Enterprises, (PROVE), Sep 2013, Dresden, Germany. pp.599-608, ⟨10.1007/978-3-642-40543-3_63⟩. ⟨hal-01463255⟩
148 Consultations
163 Téléchargements
