A Cloud–Based Approach for Collaborative Networks Supporting Serviced-Enhanced Products - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bholanathsingh Surajbali
  • Fonction : Auteur
  • PersonId : 962125
Markus Bauer
  • Fonction : Auteur
  • PersonId : 1000993
Holger Bär
  • Fonction : Auteur
  • PersonId : 1000994
Spiros Alexakis
  • Fonction : Auteur
  • PersonId : 1000995
Collaboration through sharing competencies and resources has been a key approach to both creating new competitive environments, as well as achieving the needed agility to rapidly answer to market demands. Establishing proper collaborative networks for service-enhanced products is challenging considering the wide diversity of business operations and involved resources. The creation of software solutions to support such collaboration is an effort-intensive task, especially when these solutions are designed to run in the cloud and when they are required to be highly customisable to different end-user scenarios. In this paper we describe how a cloud-based platform can support the creation of software solutions for the collaborative development and operation of highly customised and service-enhanced products. The platform has been designed based on numerous key requirements that have been generated from the analysis of different business scenarios from various use cases/domains, as well as general key requirements a cloud based platform should provide to support collaboration among organisations.
978-3-642-40543-3_7_Chapter.pdf (208.22 Ko) Télécharger le fichier
hal-01463270 , version 1 (09-02-2017)
Paternité
Bholanathsingh Surajbali, Markus Bauer, Holger Bär, Spiros Alexakis. A Cloud–Based Approach for Collaborative Networks Supporting Serviced-Enhanced Products. 14th Working Conference on Virtual Enterprises, (PROVE), Sep 2013, Dresden, Germany. pp.61-70, ⟨10.1007/978-3-642-40543-3_7⟩. ⟨hal-01463270⟩
581 Consultations
237 Téléchargements
