Robust Programming by Example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matt Bishop
  • Fonction : Auteur
  • PersonId : 983911
Chip Elliott
  • Fonction : Auteur
  • PersonId : 1001032
Robust programming lies at the heart of the type of coding called “secure programming”. Yet it is rarely taught in academia. More commonly, the focus is on how to avoid creating well-known vulnerabilities. While important, that misses the point: a well-structured, robust program should anticipate where problems might arise and compensate for them. This paper discusses one view of robust programming and gives an example of how it may be taught.
978-3-642-39377-8_15_Chapter.pdf (1.07 Mo) Télécharger le fichier
hal-01463608 , version 1 (09-02-2017)
Paternité
Matt Bishop, Chip Elliott. Robust Programming by Example. 8th World Conference on Information Security Education (WISE), Jun 2011, Lucerne, Switzerland. pp.140-147, ⟨10.1007/978-3-642-39377-8_15⟩. ⟨hal-01463608⟩
76 Consultations
1220 Téléchargements
