Investigation of DDoS Attacks by Hybrid Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
At present protection against distributed attacks of the type “denial of service” (DDoS) is one of the important tasks. The paper considers a simulation environment for DDoS attacks of different types using the combination of a simulation approach and real software-hardware testbeds. In the paper we briefly describe the system architecture and a series of experiments for DDoS attack simulation on transport and application levels. The experimental results are provided, and the analysis of these results is performed.
978-3-319-24315-3_18_Chapter.pdf (2.16 Mo) Télécharger le fichier
hal-01466218 , version 1 (13-02-2017)
Paternité
Yana Bekeneva, Konstantin Borisenko, Andrey Shorov, Igor Kotenko. Investigation of DDoS Attacks by Hybrid Simulation. 3rd International Conference on Information and Communication Technology-EurAsia (ICT-EURASIA) and 9th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Oct 2015, Daejon, South Korea. pp.179-189, ⟨10.1007/978-3-319-24315-3_18⟩. ⟨hal-01466218⟩
163 Consultations
307 Téléchargements
