A SDN Based Method of TCP Connection Handover - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Andrej Binder
  • Fonction : Auteur
  • PersonId : 1001298
Tomas Boros
  • Fonction : Auteur
  • PersonId : 1001299
Ivan Kotuliak
  • Fonction : Auteur
  • PersonId : 1001285
Today, TCP is the go-to protocol for building resilient communication channels on the Internet. Without much overstatement, it can be said that it runs the majority of communication on the planet. Its success only highlights the fact that it also has some drawbacks, of which one of the oldest ones is the inability to hand over running connections between participating hosts. This paper introduces a method that relies on the advantages of Software Defined Networks to overcome this limitation.
978-3-319-24315-3_2_Chapter.pdf (190.98 Ko) Télécharger le fichier
hal-01466230 , version 1 (13-02-2017)
Paternité
Andrej Binder, Tomas Boros, Ivan Kotuliak. A SDN Based Method of TCP Connection Handover. 3rd International Conference on Information and Communication Technology-EurAsia (ICT-EURASIA) and 9th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Oct 2015, Daejon, South Korea. pp.13-19, ⟨10.1007/978-3-319-24315-3_2⟩. ⟨hal-01466230⟩
133 Consultations
268 Téléchargements
