Software Model Creation with Multidimensional UML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ivan Polasek
  • Fonction : Auteur
  • PersonId : 1001322
Branislav Sobota
  • Fonction : Auteur
  • PersonId : 1001323
The aim of the paper is to present the advantages of the Use Cases transformation to the object layers and their visualization in 3D space to reduce complexity. Our work moves selected UML diagram from two-dimensional to multidimensional space for better visualization and readability of the structure or behaviour.Our general scope is to exploit layers for particular components or modules, time and author versions, particular object types (GUI, Business services, DB services, abstract domain classes, role and scenario classes), patterns and anti-patterns in the structure, aspects in the particular layers for solving crosscutting concerns and anti-patterns, alternative and parallel scenarios, pessimistic, optimistic and daily use scenarios.We successfully apply force directed algorithm to create more convenient automated class diagrams layout. In addition to this algorithm, we introduced semantics by adding weight factor in force calculation process.
978-3-319-24315-3_35_Chapter.pdf (436.44 Ko) Télécharger le fichier
hal-01466235 , version 1 (13-02-2017)
Paternité
Lukáš Gregorovič, Ivan Polasek, Branislav Sobota. Software Model Creation with Multidimensional UML. 3rd International Conference on Information and Communication Technology-EurAsia (ICT-EURASIA) and 9th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Oct 2015, Daejon, South Korea. pp.343-352, ⟨10.1007/978-3-319-24315-3_35⟩. ⟨hal-01466235⟩
138 Consultations
299 Téléchargements
