IP Data Delivery in HBB-Next Network Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Roman Bronis
  • Fonction : Auteur
  • PersonId : 1001324
Ivan Kotuliak
  • Fonction : Auteur
  • PersonId : 1001285
Tomas Kovacik
  • Fonction : Auteur
  • PersonId : 1001325
Peter Truchly
  • Fonction : Auteur
  • PersonId : 1001326
Andrej Binder
  • Fonction : Auteur
  • PersonId : 1001327
Digital television enables IP data delivery using various protocols. Hybrid television HbbTV enhances digital television with applications delivery. HBB-Next is an architecture which enhances HbbTV with additional features. However it does not specify IP data delivery despite it has access to both broadcast and broadband channel. This paper proposes architecture and protocols for IP data delivery in HBBNext. To achieve this goal we designed new node (Application Data Handler - ADH) in HBB-Next architecture and new communication protocols (Application Data Handler Control Protocol - ADHCP, and Hybrid Encapsulation Protocol - HEP) for data transmission. We created Stochastic Petri Net (SPN) model of designed protocols and implemented them in ns2 network simulator to verify our solution. Results of SPN model simulation and ns2 network simulation are discussed and HEP protocol is compared to existing encapsulation protocols used in DVB systems.
978-3-319-24315-3_3_Chapter.pdf (370.2 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01466236 , version 1 (13-02-2017)
Roman Bronis, Ivan Kotuliak, Tomas Kovacik, Peter Truchly, Andrej Binder. IP Data Delivery in HBB-Next Network Architecture. 3rd International Conference on Information and Communication Technology-EurAsia (ICT-EURASIA) and 9th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Oct 2015, Daejon, South Korea. pp.20-29, ⟨10.1007/978-3-319-24315-3_3⟩. ⟨hal-01466236⟩
80 Consultations
131 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
