Modeling Practices in Open Source Software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Omar Badreddin
  • Fonction : Auteur
  • PersonId : 1001504
Timothy C. Lethbridge
  • Fonction : Auteur
  • PersonId : 1001505
Maged Elassar
  • Fonction : Auteur
  • PersonId : 1001506
It is widely accepted that modeling in software engineering increases productivity and results in better code quality. Yet, modeling adoption remains low. The open source community, in particular, remains almost entirely code centric. In this paper, we explore the reasons behind such limited adoption of modeling practices among open source developers. We highlight characteristics of modeling tools that would encourage their adoption. We propose Umple as a solution where both modeling and coding elements are treated uniformly. In this approach, models can be manipulated textually and code can be edited visually. We also report on the Umple compiler itself as a case study of an open source project where contributors, using the above approach, have and continue to routinely commit code and model over a number of years.
978-3-642-38928-3_9_Chapter.pdf (673.41 Ko) Télécharger le fichier
hal-01467586 , version 1 (14-02-2017)
Paternité
Omar Badreddin, Timothy C. Lethbridge, Maged Elassar. Modeling Practices in Open Source Software. 9th Open Source Software (OSS), Jun 2013, Koper-Capodistria, Slovenia. pp.127-139, ⟨10.1007/978-3-642-38928-3_9⟩. ⟨hal-01467586⟩
156 Consultations
113 Téléchargements
