A Survey on Testing for Cyber Physical System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sara Abbaspour Asadollah
  • Fonction : Auteur
  • PersonId : 989129
Rafia Inam
  • Fonction : Auteur
  • PersonId : 1001766
Hans Hansson
  • Fonction : Auteur
  • PersonId : 989132
Cyber Physical Systems (CPS) bridge the cyber-world of computing and communications with the physical world and require development of secure and reliable software. It asserts a big challenge not only on testing and verifying the correctness of all physical and cyber components of such big systems, but also on integration of these components. This paper develops a categorization of multiple levels of testing required to test CPS and makes a comparison of these levels with the levels of software testing based on the V-model. It presents a detailed state-of-the-art survey on the testing approaches performed on the CPS. Further, it provides challenges in CPS testing.
385214_1_En_12_Chapter.pdf (7.5 Mo) Télécharger le fichier
hal-01470149 , version 1 (17-02-2017)
Paternité
Sara Abbaspour Asadollah, Rafia Inam, Hans Hansson. A Survey on Testing for Cyber Physical System. 27th IFIP International Conference on Testing Software and Systems (ICTSS), Nov 2015, Sharjah and Dubai, United Arab Emirates. pp.194-207, ⟨10.1007/978-3-319-25945-1_12⟩. ⟨hal-01470149⟩
264 Consultations
430 Téléchargements
