Discovering Authentication Credentials in Volatile Memory of Android Mobile Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dimitris Apostolopoulos
  • Fonction : Auteur
  • PersonId : 1001844
Giannis Marinakis
  • Fonction : Auteur
  • PersonId : 1001845
Christoforos Ntantogian
  • Fonction : Auteur
  • PersonId : 1001846
Christos Xenakis
  • Fonction : Auteur
  • PersonId : 1001847
This paper investigates whether authentication credentials in the volatile memory of Android mobile devices can be discovered using freely available tools. The experiments that we carried out for each application included two different sets: In the first set, our goal was to check if we could recover our own submitted credentials from the memory dump of the mobile device. In the second set of experiments, the goal was to find patterns that can indicate where the credentials are located in a memory dump of an Android device. The results revealed that the majority of the Android applications are vulnerable to credentials discovery even in case of applications that their security is critical, such as web banking and password manager applications.
978-3-642-37437-1_15_Chapter.pdf (257.79 Ko) Télécharger le fichier
hal-01470532 , version 1 (17-02-2017)
Paternité
Dimitris Apostolopoulos, Giannis Marinakis, Christoforos Ntantogian, Christos Xenakis. Discovering Authentication Credentials in Volatile Memory of Android Mobile Devices. 12th Conference on e-Business, e-Services, and e-Society (I3E), Apr 2013, Athens, Greece. pp.178-185, ⟨10.1007/978-3-642-37437-1_15⟩. ⟨hal-01470532⟩
160 Consultations
608 Téléchargements
