Methodology to Identify SMEs Needs of Internationalised and Collaborative Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper provides a methodology to support researchers in the identification of SMEs needs encountered when establishing collaborative processes within non-hierarchical manufacturing networks. Furthermore, the methodology also determines the needs when non-hierarchical networks internationalise their processes and operations to overcome globalisation and competitive environments. The major goal of this study is to provide a methodology to enable researchers to underline factors of SMEs integration with particular emphasis on the internationalisation of operations and the establishment of collaborative processes with networked partners. The provided methodology is the first step to develop a future empirical study to explore the findings of the literature review applied to SMEs and to identify the enterprises needs appeared when internationalised and collaborative processes are established in non-hierarchical networks.
978-3-642-40361-3_59_Chapter.pdf (90.51 Ko) Télécharger le fichier
hal-01470655 , version 1 (17-02-2017)
Paternité
Beatriz Andrés, Raúl Poler. Methodology to Identify SMEs Needs of Internationalised and Collaborative Networks. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.463-470, ⟨10.1007/978-3-642-40361-3_59⟩. ⟨hal-01470655⟩
212 Consultations
115 Téléchargements
