Method for Quality Appraisal in Supply Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The study of supply networks or supply chains is an emerging theme in the world of Production Engineering. The complexity of how companies relate to their networks cannot be resolved through a single management strategy anymore. At the same time, quality can no longer be seen as something inherent to individual companies. This paper studies the alignment of three important aspects: product type (functional or innovative) network strategy (agile, responsive, flexible or lean), Quality Management System - QMS (Hashin Kanri, Total Quality Management, Six Sigma and / or ISO Standards). To do this developed a method that aims to check the alignment mentioned and suggest to companies the quality management system best suited to each situation. The method presented an accuracy of over 90% in its use in research conducted.
978-3-642-40361-3_66_Chapter.pdf (297.41 Ko) Télécharger le fichier
hal-01470662 , version 1 (17-02-2017)
Paternité
João Dos Reis, Pedro De Oliveira Costa Neto. Method for Quality Appraisal in Supply Networks. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.519-526, ⟨10.1007/978-3-642-40361-3_66⟩. ⟨hal-01470662⟩
222 Consultations
103 Téléchargements
