Semantic Data Model for Operation and Maintenance of the Engineering Asset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The management of engineering assets within an organization is a challenging task that aims to optimize their performance through efficient decision making. However, the current asset data management systems suffer from poor system interoperability, data integration issues as well as an enormous amount of stored data, thus preventing a seamless flow of information. The aim of this work is to propose a semantic data model for engineering asset management, focusing on the operation and maintenance phase of its life cycle. Ontologies are proposed because they can capture the semantics of data, create a shared vocabulary to describe the knowledge for sharing in the domain and provide reasoning capabilities. This model will gather all the knowledge necessary to assist in the decision making process in order to improve the asset’s availability, longevity and quality of operations.
978-3-642-40361-3_7_Chapter.pdf (209.4 Ko) Télécharger le fichier
hal-01470677 , version 1 (17-02-2017)
Paternité
Andreas Koukias, Dražen Nadoveza, Dimitris Kiritsis. Semantic Data Model for Operation and Maintenance of the Engineering Asset. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.49-55, ⟨10.1007/978-3-642-40361-3_7⟩. ⟨hal-01470677⟩
248 Consultations
402 Téléchargements
