Base Stock Inventory Systems with Compound Poisson Demand: Case of Partial Lost Sales - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
M. Zied Babai
  • Fonction : Auteur
  • PersonId : 875590
Ziad Jemai
  • Fonction : Auteur
  • PersonId : 907663
Yves Dallery
In this paper we extend earlier work that analyzes a single echelon single item base-stock inventory system where Demand is modeled as a compound Poisson process and the lead-time is stochastic. The extension consists in considering a cost oriented system where unfilled demands are lost. The case of partial lost sales is assumed. We first model the inventory system as a Makovian M/G/( queue then we propose a method to calculate numerically the optimal base-stock level. A preliminary numerical investigation is also conducted to show the performance of our solution.
978-3-642-40361-3_88_Chapter.pdf (259.86 Ko) Télécharger le fichier
hal-01470686 , version 1 (17-02-2017)
Paternité
M. Zied Babai, Ziad Jemai, Yves Dallery. Base Stock Inventory Systems with Compound Poisson Demand: Case of Partial Lost Sales. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.693-698, ⟨10.1007/978-3-642-40361-3_88⟩. ⟨hal-01470686⟩
194 Consultations
1070 Téléchargements
