Discrete Part Manufacturing Energy Efficiency Improvements with Modelling and Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Juhani Heilala
  • Fonction : Auteur
  • PersonId : 875397
Marja Paju
  • Fonction : Auteur
  • PersonId : 1002128
Jari Montonen
  • Fonction : Auteur
  • PersonId : 875399
Reino Ruusu
  • Fonction : Auteur
  • PersonId : 1002129
Mikel Sorli
  • Fonction : Auteur
  • PersonId : 930850
Alberto Armijo
  • Fonction : Auteur
  • PersonId : 1002112
Pablo Bermell-Garcia
  • Fonction : Auteur
  • PersonId : 915383
Simon Astwood
  • Fonction : Auteur
  • PersonId : 1002130
Santiago Quintana
  • Fonction : Auteur
  • PersonId : 1002131
Energy efficiency has become a key concern in industry due to increased energy cost and associated environmental impacts. It is as well factor on marketing and reputation. Customers require information on the ecological performance of products and the process to build that product. Therefore eco-efficient manufacturing is in our days a matter of competitiveness and economic success. This paper presents industrial driven research and the key findings from production eco and energy efficiency analysis and development projects. Both static and dynamic multi-level modelling and simulation is covered with examples. The use of Value Stream Mapping and Discrete Event Simulation with life cycle inventory data for production eco efficiency analysis is explained. Generic developement steps for process, machine and production system model with environmantal aspects is shown. Development continues in EPES “Eco Process Engineering System for Composition of Services to Optimise Product Life-Cycle”- project.
978-3-642-40352-1_19_Chapter.pdf (397 Ko) Télécharger le fichier
hal-01472234 , version 1 (20-02-2017)
Paternité
Juhani Heilala, Marja Paju, Jari Montonen, Reino Ruusu, Mikel Sorli, et al.. Discrete Part Manufacturing Energy Efficiency Improvements with Modelling and Simulation. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.142-150, ⟨10.1007/978-3-642-40352-1_19⟩. ⟨hal-01472234⟩
121 Consultations
165 Téléchargements
