Toward Energy Efficient Manufacturing: A Study on Practices and Viewpoint of the Industry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gökan May
  • Fonction : Auteur
  • PersonId : 1002132
Marco Taisch
  • Fonction : Auteur
  • PersonId : 931901
Bojan Stahl
  • Fonction : Auteur
  • PersonId : 991606
Vahid Sadr
  • Fonction : Auteur
  • PersonId : 1002133
The main objective of this study is to assess current situation and applications in the industry with respect to energy efficiency. From literature, a four pillar framework (strategy, tool, process, technology) has been developed, outlining the essential elements to successfully integrate energy efficiency in manufacturing. Based on the framework, a questionnaire is developed to assess manufacturing companies in Europe. How and what companies are doing currently to integrate energy efficiency in their manufacturing is under investigation through surveys and complementary case studies. This paper presents a fact finding study, aimed to understand the main motivations, limitations, and effectiveness of integrating energy efficiency in manufacturing. Hence, this study intends to establish a basis for the companies and academia to have a holistic understanding on energy efficient practices as a first step on the way to integrate energy efficiency in manufacturing. Consequently, the gaps between theory and practice are revealed.
978-3-642-40352-1_1_Chapter.pdf (241.74 Ko) Télécharger le fichier
hal-01472235 , version 1 (20-02-2017)
Paternité
Gökan May, Marco Taisch, Bojan Stahl, Vahid Sadr. Toward Energy Efficient Manufacturing: A Study on Practices and Viewpoint of the Industry. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.1-8, ⟨10.1007/978-3-642-40352-1_1⟩. ⟨hal-01472235⟩
123 Consultations
475 Téléchargements
