Knowledge Management in Set Based Lean Product Development Process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Robert Furian
  • Fonction : Auteur
  • PersonId : 1002163
Frank Von Lacroix
  • Fonction : Auteur
  • PersonId : 1002164
Dragan Stokic
  • Fonction : Auteur
  • PersonId : 1002165
Ana Correia
  • Fonction : Auteur
  • PersonId : 1002166
Cristina Grama
  • Fonction : Auteur
  • PersonId : 1002167
Stefan Faltus
  • Fonction : Auteur
  • PersonId : 1002168
Maksim Maksimovic
  • Fonction : Auteur
  • PersonId : 1002169
Christiane Beyer
  • Fonction : Auteur
  • PersonId : 1002170
The objective of the research is to examine and develop new methods and tools for management of knowledge in Lean Product development. Lean Product development attempts to apply lean philosophy and principles within product development process. Special emphasis is given to the so-called Set Based Lean Design principles. Such product development process requires innovative methodologies and tools for capturing, reuse and provision of knowledge needed for decision making, as well as advanced ICT environment for Knowledge Management (KM).A Set Based Lean Design toolkit is developed, aiming to support the product developer in making decisions during the development process. This toolkit includes the Lean Knowledge Life Cycle methodology and a set of software tools for KM. The application of the methods and tools is investigated within large automotive industry and its supplier.
978-3-642-40352-1_46_Chapter.pdf (213.38 Ko) Télécharger le fichier
hal-01472264 , version 1 (20-02-2017)
Paternité
Robert Furian, Frank Von Lacroix, Dragan Stokic, Ana Correia, Cristina Grama, et al.. Knowledge Management in Set Based Lean Product Development Process. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.368-375, ⟨10.1007/978-3-642-40352-1_46⟩. ⟨hal-01472264⟩
259 Consultations
261 Téléchargements
