Logarithmic stability of parabolic Cauchy problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The uniqueness of parabolic Cauchy problems is nowadays a classical problem and since Hadamard [4] these kind of problems are known to be ill-posed and even severely ill-posed. Until now there are only few partial results concerning the quantification in the stability for parabolic Cauchy problems. In the present article, we bring the complete answer to this issue.
Cauchy_Parabolic_hal1.pdf (198.45 Ko) Télécharger le fichier
hal-01472597 , version 1 (21-02-2017)
hal-01472597 , version 2 (04-06-2017)
hal-01472597 , version 3 (03-06-2018)
Mourad Choulli, Masahiro Yamamoto. Logarithmic stability of parabolic Cauchy problems. 2017. ⟨hal-01472597v1⟩
177 Consultations
123 Téléchargements
