Stochastic Composite Least-Squares Regression with Convergence Rate O(1/n) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the optimization of a quadratic objective function whose gradients are only accessible through a stochastic oracle that returns the gradient at any given point plus a zero-mean finite variance random error. We present the first algorithm that achieves jointly the optimal prediction error rates for least-squares regression, both in terms of forgetting of initial conditions in O(1/n 2), and in terms of dependence on the noise and dimension d of the problem, as O(d/n). Our new algorithm is based on averaged accelerated regularized gradient descent, and may also be analyzed through finer assumptions on initial conditions and the Hessian matrix, leading to dimension-free quantities that may still be small while the " optimal " terms above are large. In order to characterize the tightness of these new bounds, we consider an application to non-parametric regression and use the known lower bounds on the statistical performance (without computational limits), which happen to match our bounds obtained from a single pass on the data and thus show optimality of our algorithm in a wide variety of particular trade-offs between bias and variance.
hal-mdh.pdf (501.33 Ko) Télécharger le fichier
hal-01472867 , version 1 (21-02-2017)
Nicolas Flammarion, Francis Bach. Stochastic Composite Least-Squares Regression with Convergence Rate O(1/n). Proceedings of The 30th Conference on Learning Theory, (COLT), 2017, Amsterdam, Netherlands. ⟨hal-01472867⟩
506 Consultations
1333 Téléchargements
