Combination of Process Mining and Simulation Techniques for Business Process Redesign: A Methodological Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Santiago Aguirre
  • Fonction : Auteur
  • PersonId : 1002430
Carlos Parra
  • Fonction : Auteur
  • PersonId : 1002431
Jorge Alvarado
  • Fonction : Auteur
  • PersonId : 1002432
Organizations of all sizes are currently supporting their performance on information systems that record the real execution of their business processes in event logs. Process mining tools analyze the log to provide insight on the real problems of the process, as part of the diagnostic phase. Nonetheless, to complete the lifecycle of a process, the latter has to be redesigned, a task for which simulation techniques can be used in combination with process mining, in order to evaluate different improvement alternatives before they are put in practice. In this context, the current work presents a methodological approach to the integration of process mining and simulation techniques in a process redesign project.
978-3-642-40919-6_2_Chapter.pdf (1.24 Mo) Télécharger le fichier
hal-01474688 , version 1 (23-02-2017)
Paternité
Santiago Aguirre, Carlos Parra, Jorge Alvarado. Combination of Process Mining and Simulation Techniques for Business Process Redesign: A Methodological Approach. 2nd International Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), Jun 2012, Campione d’Italia, Italy. pp.24-43, ⟨10.1007/978-3-642-40919-6_2⟩. ⟨hal-01474688⟩
154 Consultations
506 Téléchargements
