From Information Systems to Information Services Systems: Designing the Transformation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Service-orientation is currently considered as a promising paradigm to deal with the complexity, interoperability and evolution of enterprise Information Systems (IS), which are the foremost preoccupation in today’s enterprises. However, the shift from a conventional IS architecture to a service-oriented one is not an easy task despite of the various service design approaches proposed in the literature. In this paper we promote the concepts of information service and Information Services System (ISS) and we present three different ways to design an ISS taking into account enterprise legacy IS and/or from scratch. We illustrate the three approaches with examples taken from industrial projects and case studies.
978-3-642-41641-5_6_Chapter.pdf (1001.23 Ko) Télécharger le fichier
hal-01474756 , version 1 (23-02-2017)
Paternité
Jolita Ralyté, Abdelaziz Khadraoui, Michel Léonard. From Information Systems to Information Services Systems: Designing the Transformation. 6th The Practice of Entrprise Modeling (PoEM), Nov 2013, Riga, Latvia. pp.69-84, ⟨10.1007/978-3-642-41641-5_6⟩. ⟨hal-01474756⟩
140 Consultations
133 Téléchargements
