Ephémérides des satellites faibles de Jupiter et de Saturne pour 1988 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1987
In the following tables are given the ephemerides of the satellites J VI, J VII, J VIII and J IX of Jupiter, and of the satellite Phoebe (S IX) of Saturn. These ephemerides come from numerical integration of the G.B.S. type (Gragg-Bulirsch-Stoer, 1966). The numerical constants of integration are those used by T.V. Bordovystina and L.E. Bykova(l978) for J VI and J VII, by K.A. Aksnes(1973) for J VIII and J IX and by L.E. Rose(l979) for Phoebe. For these satellites, these constants are adjusted by comparison with the observations. The published quantities are equatorial, geocentric and astrometric coordinates. For each year, we find successively the ephemerides for J VI, J VII, J VIII ,J IX, Jupiter and Phoebe developed into Chebyshev series. Each development covers 33 days beginning by the day before the first day in the month, numbered zero. The developments contain 10 coefficients, numbered from zero to nine, the value above the table of coefficients corresponds to the starting date in the given interval of time. The right ascension is expressed in hour, the declination in degree and the distance in A.U. The argument of the series is the ephemeris time (T.E) expressed in Julian days. The planetary ephemerides have been computed from D l02(J.P.L. ephemerides). The published coefficients are such that precision of 0.01 second of time in right ascension, 0.1 second of degree in declination and 1.10-6 A.U in distance, is obtained. This supplement will be published every year, with eventually new satellites.
Une plus grande facilité actuelle d’observation des satellites faibles du système solaire nous a incités à élaborer des éphémérides pour ceux-ci. Dans un premier temps, nous proposons des éphémérides des satellites J VI, J VII, J VIII et J IX de Jupiter et du satellite Phoebé (S IX) de Saturne. Ces éphémérides sont obtenues à partir d ’intégrations numériques et publiées sous Ia forme de séries de polynômes de Tchebycheff, présentation utilisée dans Ia Connaissance des Temps depuis. 1980. Les observations de ces satellites étant essentiellement photographiques, nous publions les coordonnées astrométriques géocentriques de ces satellites. Pour permettre un passage à des coordonnées différentielles dans Ie cas des satellites de Jupiter, nous publions également les éphémérides de celui-ci dans Ie même système de coordonnées; dans Ie cas de Phoebé, nous donnons directement les coordonnées du satellite par rapport à Saturne. Nous présentons to u t d’abord un tableau des caractéristiques des satellites de Jupiter et de Saturne, dont nous donnons ici les éphémérides. Ce supplément sera édité tous les ans avec, éventuellement, adjonction de nouveaux satellites. L’ensemble des calculs a été réalisé au Centre Inter Régional de Calcul Electronique d ’Orsay (CIRCE)
IMCCE-satJupiterSaturne_1988.pdf (1.9 Mo) Télécharger le fichier
hal-01478897 , version 1 (28-02-2017)
  • HAL Id : hal-01478897 , version 1
A. Bec-Borsenberger, P. Rocher. Ephémérides des satellites faibles de Jupiter et de Saturne pour 1988. [Rapport de recherche] Institut de mécanique céleste et de calcul des éphémérides(IMCCE). 1987, 24 p.,tables. ⟨hal-01478897⟩
160 Consultations
57 Téléchargements
