Cloud-Based E-Learning: A Proposed Model and Benefits by Using E-Learning Based on Cloud Computing for Educational Institution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nungki Selviandro
  • Fonction : Auteur
  • PersonId : 1003065
Zainal Arifin Hasibuan
  • Fonction : Auteur
  • PersonId : 993424
The increasing research in the areas of information technology have a positive impact in the world of education. The implementation of e-learning is one of contribution from information technology to the world of education. The implementation of e-learning has been implemented by several educational institutions in Indonesia. E-Learning provides many benefits such as flexibility, diversity, measurement, and so on. The current e-learning applications required large investments in infrastructure systems regardless of commercial or open source e-learning application. If the institution tended to use open source e-learning application it would need more cost to hire professional staff to maintain and upgrade the e-learning application. It can be challenging to implement e-learning in educational institutions. Another problem that can arise in the use of e-laerning trend today is more likely to institution building their own e-learning system itself. If two or more institutions are willing to build and use an e-learning so they can minimize the expenditure to develop the system and share learning materials more likely happened. This paper discuss the current state and challenges in e-learning and then explained the basic concept and previous proposed architectures of cloud computing. In this paper authors also proposed a model of cloud-based e-learning that consists of five layer, namely: (1) infrastructure layer; (2) platform layer; (3) application layer; (4) access layer; and (5) user layer. In addition to this paper we also illustrated the shift paradigm from conventional e-learning to cloud-based e-learning and described the expected benefits by using cloud-based e-learning.
978-3-642-36818-9_20_Chapter.pdf (576.76 Ko) Télécharger le fichier
hal-01480175 , version 1 (01-03-2017)
Paternité
Nungki Selviandro, Zainal Arifin Hasibuan. Cloud-Based E-Learning: A Proposed Model and Benefits by Using E-Learning Based on Cloud Computing for Educational Institution. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.192-201, ⟨10.1007/978-3-642-36818-9_20⟩. ⟨hal-01480175⟩
313 Consultations
969 Téléchargements
