A Block Cipher Mode of Operation with Two Keys - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yi-Li Huang
  • Fonction : Auteur
  • PersonId : 994586
Fang-Yie Leu
  • Fonction : Auteur
  • PersonId : 993460
Jung-Chun Liu
  • Fonction : Auteur
  • PersonId : 1003100
Jing-Hao Yang
  • Fonction : Auteur
  • PersonId : 994588
In this paper, we propose a novel block cipher mode of operation (BCMO for short), named Output Protection Chain (OPC for short), which as a symmetric encryption structure is different from other existing BCMOs in that it employs two keys, rather than one key, to protect the output of the mode. The security threats of chosen-plaintext attacks on three existing common BCMOs, including the Cipher Feedback mode (CFB), the Output Feedback mode (OFB), and the Counter mode (CTR), are also analyzed. After that, we explain why the OPC mode (or simply the OPC) can effectively avoid chosen-plaintext attacks, and why its security level is higher than those of CFB, OFB, and CTR.
978-3-642-36818-9_43_Chapter.pdf (463.5 Ko) Télécharger le fichier
hal-01480198 , version 1 (01-03-2017)
Paternité
Yi-Li Huang, Fang-Yie Leu, Jung-Chun Liu, Jing-Hao Yang. A Block Cipher Mode of Operation with Two Keys. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.392-398, ⟨10.1007/978-3-642-36818-9_43⟩. ⟨hal-01480198⟩
57 Consultations
359 Téléchargements
