Shifting Primes on OpenRISC Processors with Hardware Multiplier - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Leandro Marin
  • Fonction : Auteur
  • PersonId : 993498
Antonio J. Jara
  • Fonction : Auteur
  • PersonId : 1003165
Antonio Skarmeta
  • Fonction : Auteur
  • PersonId : 910734
Shifting primes have proved its efficiency in CPUs without hardware multiplier such as the located at the MSP430 from Texas Instruments. This work analyzes and presents the advantages of the shifting primes for CPUs with hardware multiplier such as the JN5139 from NXP/Jennic based on an OpenRISC architecture. This analysis is motivated because Internet of Things is presenting several solutions and use cases where the integrated sensors and actuators are sometimes enabled with higher capabilities. This work has concluded that shifting primes are offering advantages with respect to other kind of primes for both with and without hardware multiplier. Thereby, offering a suitable cryptography primitives based on Elliptic Curve Cryptography (ECC) for the different families of chips used in the Internet of Things solutions. Specifically, this presents the guidelines to optimize the implementation of ECC when it is presented a limited number of registers.
978-3-642-36818-9_63_Chapter.pdf (231.72 Ko) Télécharger le fichier
hal-01480261 , version 1 (01-03-2017)
Paternité
Leandro Marin, Antonio J. Jara, Antonio Skarmeta. Shifting Primes on OpenRISC Processors with Hardware Multiplier. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.540-549, ⟨10.1007/978-3-642-36818-9_63⟩. ⟨hal-01480261⟩
160 Consultations
191 Téléchargements
