CaPTIF: Comprehensive Performance TestIng Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present the design and implementation of a framework for comprehensive performance evaluation of algorithms, modules, and libraries. Our framework allows for the definition of well-defined test inputs and the subsequent scheduling and execution of structured tests. In addition, the framework provides a web-based interface for user interaction and allows for the convenient browsing, plotting, and statistical analysis of test results. We furthermore report on our experience in using the new framework in the development of cryptographic protocols and algorithms—specifically in the context of secure multi-party computation.
978-3-642-34691-0_6_Chapter.pdf (486.81 Ko) Télécharger le fichier
hal-01482411 , version 1 (03-03-2017)
Paternité
Daniel A. Mayer, Orie Steele, Susanne Wetzel, Ulrike Meyer. CaPTIF: Comprehensive Performance TestIng Framework. 24th International Conference on Testing Software and Systems (ICTSS), Nov 2012, Aalborg, Denmark. pp.55-70, ⟨10.1007/978-3-642-34691-0_6⟩. ⟨hal-01482411⟩
134 Consultations
48 Téléchargements
