Bearing Rigidity Maintenance for Formations of Quadrotor UAVs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers the problem of controlling a formation of quadrotor UAVs equipped with onboard cameras with the goal of maintaining bearing rigidity during motion despite the presence of several sensing constraints, that is, minimum/maximum range, limited camera field of view, and possible occlusions caused by the agents of the formation. To this end, a decentralized gradient-based control action is developed , based on a suitable 'degree of infinitesimal rigidity' linked to the spectral properties of the bearing rigidity matrix. The approach is then experimentally validated with five quadrotor UAVs.
ICRA17_0837_FI.pdf (3.21 Mo) Télécharger le fichier
hal-01482422 , version 1 (03-03-2017)
hal-01482422 , version 2 (13-08-2017)
  • HAL Id : hal-01482422 , version 1
Fabrizio Schiano, Paolo Robuffo Giordano. Bearing Rigidity Maintenance for Formations of Quadrotor UAVs. IEEE Int. Conf. on Robotics and Automation, ICRA'17, May 2017, Singapore, Singapore. ⟨hal-01482422v1⟩
396 Consultations
345 Téléchargements
