Oleylamine-assisted solvothermal synthesis of copper antimony sulfide nanocrystals: Morphology and phase control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Materials Research Bulletin Année : 2017
We report a one-pot synthesis of copper antimony sulfide nanocrystals by a facile and easily scalable route using a surfactant assisted solvothermal method. Phase-pure and quasi-monodisperse Cu3SbS4 nanocrystals have successfully been synthetized by adjusting the sulfur to copper molar ratio as well as the surfactant to solvent volumetric ratio. Nanocrystals morphology and chemical composition are characterized. As synthetized and purified nanocrystals are formulated into a colloidal suspension in order to fabricate copper antimony sulfide films. Morphological, electrical and optical characterizations of famatinite films are conducted. The electrical resistivity of the as deposited films is comprised between 10 Ω cm and 48 Ω cm. The optical gap is found to be indirect with a value of 0.82 eV.
Matériaux
MBella-CASNanocrystals_r1.pdf (747.7 Ko) Télécharger le fichier
hal-01483318 , version 1 (26-04-2018)
M Bella, C. Rivero, S. Blayac, H Basti, M C Record, et al.. Oleylamine-assisted solvothermal synthesis of copper antimony sulfide nanocrystals: Morphology and phase control. Materials Research Bulletin, 2017, 90, pp.188-194. ⟨10.1016/j.materresbull.2017.02.036⟩. ⟨hal-01483318⟩
215 Consultations
1015 Téléchargements
