A Voronoi Interface approach to cell aggregate electropermeabilization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2017
We present a Voronoi Interface approach to the study of cell electropermeabilization. We consider the nonlinear electropermeabilization model of Poignard et al. [20], which takes into account the jump in the voltage potential across cells' membrane. The jump condition is imposed in a sharp manner, using the Voronoi Interface Method of Guittet et al. [14], while adaptive Quad-/Oc-tree grids are employed to automatically refine near the cells boundary for increased accuracy. Numerical results are provided to illustrate the accuracy of the methods. We also carry out simulations in three spatial dimensions to investigate the influence of shadowing and of the cells shape on the degree of permeabilization.
Revision_JCP_11_21_2016.pdf (30.53 Mo) Télécharger le fichier
hal-01483521 , version 1 (06-03-2017)
Arthur Guittet, Clair Poignard, Frederic Gibou. A Voronoi Interface approach to cell aggregate electropermeabilization. Journal of Computational Physics, 2017, 332, pp.143 - 159. ⟨10.1016/j.jcp.2016.11.048⟩. ⟨hal-01483521⟩
476 Consultations
187 Téléchargements
