Post hoc inference via joint family-wise error rate control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We introduce a general methodology for post hoc inference in a large-scale multiple testing framework. The approach is called " user-agnostic " in the sense that the statistical guarantee on the number of correct rejections holds for any set of candidate items selected by the user (after having seen the data). This task is investigated by defining a suitable criterion, named the joint-family-wise-error rate (JER for short). We propose several procedures for controlling the JER, with a special focus on incorporating dependencies while adapting to the unknown quantity of signal (via a step-down approach). We show that our proposed setting incorporates as particular cases a version of the higher criticism as well as the closed testing based approach of Goeman and Solari (2011). Our theoretical statements are supported by numerical experiments.
BNR2017.pdf (651.53 Ko) Télécharger le fichier
hal-01483585 , version 1 (06-03-2017)
hal-01483585 , version 2 (09-03-2017)
hal-01483585 , version 3 (10-03-2017)
hal-01483585 , version 4 (06-01-2018)
hal-01483585 , version 5 (10-04-2019)
Gilles Blanchard, Pierre Neuvial, Etienne Roquain. Post hoc inference via joint family-wise error rate control. 2017. ⟨hal-01483585v3⟩
1233 Consultations
591 Téléchargements
