Using Bloom Filters to Ensure Access Control and Authentication Requirements for SCADA Field Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The critical infrastructure cannot operate without SCADA systems; this has made the task of securing SCADA systems a national security priority. While progress has been made in securing control networks, security at the field device level is still lacking. Field devices present unique security challenges and these challenges are compounded by the presence of legacy devices. This paper describes a technique that uses Bloom filters to implement challenge-response authentication and role-based access control in field devices. The approach, which is implemented in an in-line security pre-processor, provides for rapid and constant access check times. Experiments involving a prototype device demonstrate that the false positive rate can be kept arbitrarily low and that the real-time performance is acceptable for many SCADA applications.
978-3-642-35764-0_7_Chapter.pdf (1.05 Mo) Télécharger le fichier
hal-01483822 , version 1 (06-03-2017)
Paternité
Jeffrey Hieb, Jacob Schreiver, James Graham. Using Bloom Filters to Ensure Access Control and Authentication Requirements for SCADA Field Devices. 6th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2012, Washington, DC, United States. pp.85-97, ⟨10.1007/978-3-642-35764-0_7⟩. ⟨hal-01483822⟩
87 Consultations
255 Téléchargements
