URANOS: User-Guided Rewriting for Plugin-Enabled ANdroid ApplicatiOn Security - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Daniel Schreckling
  • Fonction : Auteur
  • PersonId : 1003790
Stephan Huber
  • Fonction : Auteur
  • PersonId : 1003791
Focke Höhne
  • Fonction : Auteur
  • PersonId : 1003792
Joachim Posegga
  • Fonction : Auteur
  • PersonId : 1003788
URANOS is an Android application which uses syntactical static analysis to determine in which component of an Android application a permission is required. This work describes how the detection and analysis of widely distributed and security critical ad-ware plugins is achieved. We show, how users can trigger bytecode rewriting to (de)activate selected or redundant permissions in Android applications without sacrificing functionality. The paper also discusses performance, security, and legal implications of the presented approach.
978-3-642-38530-8_4_Chapter.pdf (411.25 Ko) Télécharger le fichier
hal-01485933 , version 1 (09-03-2017)
Paternité
Daniel Schreckling, Stephan Huber, Focke Höhne, Joachim Posegga. URANOS: User-Guided Rewriting for Plugin-Enabled ANdroid ApplicatiOn Security. 7th International Workshop on Information Security THeory and Practice (WISTP), May 2013, Heraklion, Greece. pp.50-65, ⟨10.1007/978-3-642-38530-8_4⟩. ⟨hal-01485933⟩
42 Consultations
133 Téléchargements
