Failure Analysis and Modeling in Large Multi-site Infrastructures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Every large multi-site infrastructure such as Grids and Clouds must implement fault-tolerance mechanisms and smart schedulers to enable continuous operation even when resource failures occur. Evaluating the efficiency of such mechanisms and schedulers requires representative failure models that are able to capture realistic properties of real world failure data. This paper shows that failures in multi-site infrastructures are far from being randomly distributed. We propose a failure model that captures features observed in real failure traces.
978-3-642-38541-4_10_Chapter.pdf (359.49 Ko) Télécharger le fichier
hal-01489451 , version 1 (14-03-2017)
Paternité
Tran Ngoc Minh, Guillaume Pierre. Failure Analysis and Modeling in Large Multi-site Infrastructures. 13th International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2013, Florence, Italy. pp.127-140, ⟨10.1007/978-3-642-38541-4_10⟩. ⟨hal-01489451⟩
238 Consultations
70 Téléchargements
