Abstract : Since a lot of the networks do not apply source IP filtering to its outgoing traffic, an attacker may insert an arbitrary source IP address in an outgoing packet, i.e., IP address spoofing. This paper elaborates on a possibility to detect the spoofing in a large network peering with other networks. A proposed detection scheme is based on an analysis of NetFlow data collected at the entry points in the network. The scheme assumes that the network traffic originating from a certain source network enters the network under surveillance via a relatively stable set of points. The scheme has been tested on data from the real network.
https://hal.inria.fr/hal-01489972 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, March 14, 2017 - 5:06:34 PM Last modification on : Wednesday, November 18, 2020 - 7:20:08 PM Long-term archiving on: : Thursday, June 15, 2017 - 3:10:51 PM
Michal Kováčik, Michal Kajan, Martin Žádník. Detecting IP Spoofing by Modelling History of IP Address Entry Points. 7th International Conference on Autonomous Infrastructure (AIMS), Jun 2013, Barcelona, Spain. pp.73-83, ⟨10.1007/978-3-642-38998-6_9⟩. ⟨hal-01489972⟩
