Detecting IP Spoofing by Modelling History of IP Address Entry Points - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
Michal Kováčik
  • Function : Author
  • PersonId : 1004087
Michal Kajan
  • Function : Author
  • PersonId : 1004088
Martin Žádník
  • Function : Author
  • PersonId : 994069
Since a lot of the networks do not apply source IP filtering to its outgoing traffic, an attacker may insert an arbitrary source IP address in an outgoing packet, i.e., IP address spoofing. This paper elaborates on a possibility to detect the spoofing in a large network peering with other networks. A proposed detection scheme is based on an analysis of NetFlow data collected at the entry points in the network. The scheme assumes that the network traffic originating from a certain source network enters the network under surveillance via a relatively stable set of points. The scheme has been tested on data from the real network.
978-3-642-38998-6_9_Chapter.pdf (245.25 Ko) Télécharger le fichier
Dates and versions
hal-01489972 , version 1 (14-03-2017)
Attribution
Identifiers
Cite
Michal Kováčik, Michal Kajan, Martin Žádník. Detecting IP Spoofing by Modelling History of IP Address Entry Points. 7th International Conference on Autonomous Infrastructure (AIMS), Jun 2013, Barcelona, Spain. pp.73-83, ⟨10.1007/978-3-642-38998-6_9⟩. ⟨hal-01489972⟩
69 View
1035 Download
Share
