Bloom Filter Bootstrap: Privacy-Preserving Estimation of the Size of an Intersection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hiroaki Kikuchi
  • Fonction : Auteur
  • PersonId : 1004130
Jun Sakuma
  • Fonction : Auteur
  • PersonId : 1004131
This paper proposes a new privacy-preserving scheme for estimating the size of the intersection of two given secret subsets. Given the inner product of two Bloom filters (BFs) of the given sets, the proposed scheme applies Bayesian estimation under assumption of beta distribution for an a priori probability of the size to be estimated. The BF retains the communication complexity and the Bayesian estimation improves the estimation accuracy.An possible application of the proposed protocol is an epidemiological datasets regarding two attributes, Helicobactor pylori infection and stomach cancer. Assuming information related to Helicobactor Pylori infection and stomach cancer are separately collected, the protocol demonstrates that a χ2-test can be performed without disclosing the contents of the two confidential databases.
978-3-642-39256-6_10_Chapter.pdf (165.75 Ko) Télécharger le fichier
hal-01490702 , version 1 (15-03-2017)
Paternité
Hiroaki Kikuchi, Jun Sakuma. Bloom Filter Bootstrap: Privacy-Preserving Estimation of the Size of an Intersection. 27th Data and Applications Security and Privacy (DBSec), Jul 2013, Newark, NJ, United States. pp.145-163, ⟨10.1007/978-3-642-39256-6_10⟩. ⟨hal-01490702⟩
34 Consultations
132 Téléchargements
