Using Safety Constraint for Transactional Dataset Anonymization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bechara Al Bouna
  • Fonction : Auteur
  • PersonId : 1004132
Chris Clifton
  • Fonction : Auteur
  • PersonId : 1004133
Qutaibah Malluhi
  • Fonction : Auteur
  • PersonId : 1004134
In this paper, we address privacy breaches in transactional data where individuals have multiple tuples in a dataset. We provide a safe grouping principle to ensure that correlated values are grouped together in unique partitions that enforce l-diversity at the level of individuals. We conduct a set of experiments to evaluate privacy breach and the anonymization cost of safe grouping.
978-3-642-39256-6_11_Chapter.pdf (481.64 Ko) Télécharger le fichier
hal-01490703 , version 1 (15-03-2017)
Paternité
Bechara Al Bouna, Chris Clifton, Qutaibah Malluhi. Using Safety Constraint for Transactional Dataset Anonymization. 27th Data and Applications Security and Privacy (DBSec), Jul 2013, Newark, NJ, United States. pp.164-178, ⟨10.1007/978-3-642-39256-6_11⟩. ⟨hal-01490703⟩
45 Consultations
108 Téléchargements
