An Approach to Select Cost-Effective Risk Countermeasures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Security risk analysis should be conducted regularly to maintain an acceptable level of security. In principle, all risks that are unacceptable according to the predefined criteria should be mitigated. However, risk mitigation comes at a cost, and only the countermeasures that cost-efficiently mitigate risks should be implemented. This paper presents an approach to integrate the countermeasure cost-benefit assessment into the risk analysis and to provide decision makers with the necessary decision support. The approach comes with the necessary modeling support, a calculus for reasoning about the countermeasure cost and effect, as well as means for visualization of the results to aid decision makers.
978-3-642-39256-6_18_Chapter.pdf (856.68 Ko) Télécharger le fichier
hal-01490710 , version 1 (15-03-2017)
Paternité
Le Sang Tran, Bjørnar Solhaug, Ketil Stølen. An Approach to Select Cost-Effective Risk Countermeasures. 27th Data and Applications Security and Privacy (DBSec), Jul 2013, Newark, NJ, United States. pp.266-273, ⟨10.1007/978-3-642-39256-6_18⟩. ⟨hal-01490710⟩
81 Consultations
395 Téléchargements
