Process Management Challenges in Swedish Public Sector: A Bottom Up Initiative - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Carl-Mikael Lönn
  • Fonction : Auteur
  • PersonId : 1004208
Elin Uppström
  • Fonction : Auteur
  • PersonId : 1004209
Public administration is under pressure to work more effectively and increase effectiveness with regards to internal administrative processes as well as level of service towards citizens. This paper identifies process management challenges encountered in Swedish municipalities and provides concrete examples of consequences of these challenges by using a bottom up approach. It is done by using a common public service process and a mobile solution as platform for discussions with municipal officials working with the process. To categorise the challenges they are grouped into six core categories of business process management, which provide a picture of challenges that municipalities face today. Results show that Swedish municipalities face challenges in all categories and that it was not possible to design a generic process for the analysed service. To initiate work with improving process maturity in local governments the bottom up approach used was found successful.
978-3-642-40358-3_18_Chapter.pdf (97.45 Ko) Télécharger le fichier
hal-01490908 , version 1 (16-03-2017)
Paternité
Carl-Mikael Lönn, Elin Uppström. Process Management Challenges in Swedish Public Sector: A Bottom Up Initiative. 12th International Conference on Electronic Government (EGOV), Sep 2013, Koblenz, Germany. pp.212-223, ⟨10.1007/978-3-642-40358-3_18⟩. ⟨hal-01490908⟩
160 Consultations
187 Téléchargements
