Social Media Participation and Local Politics: A Case Study of the Enschede Council in the Netherlands - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Robin Effing
  • Fonction : Auteur
  • PersonId : 1004262
Jos Van Hillegersberg
  • Fonction : Auteur
  • PersonId : 1004263
Theo C. Huibers
  • Fonction : Auteur
  • PersonId : 1004264
Social media such as Facebook, Twitter and YouTube are often seen as political game changers. Yet little is known of the effects of social media on local politics. In this paper the Social Media Participation Model (SMPM) is introduced for studying the effects of social media on local political communities. The SMPM aims to explore the relationship between Social Media Participation and Community Participation. The model comprises four constructs: Social Media Choice, Social Media Use, Sense of Community and Community Engagement. The design of the case study was based on the SMPM and took place among the members and parties of the Enschede council, from a large municipality in the Netherlands. Social media participation levels were measured and compared with the Social Media Indicator (SMI). A negative correlation between Social Media Use and Sense of Community has been discovered. However, we could not find a causal effect that explains this correlation. To analyze the effects in more detail, we show directions for further improvement of the model.
978-3-642-40346-0_6_Chapter.pdf (200.77 Ko) Télécharger le fichier
hal-01491231 , version 1 (16-03-2017)
Paternité
Robin Effing, Jos Van Hillegersberg, Theo C. Huibers. Social Media Participation and Local Politics: A Case Study of the Enschede Council in the Netherlands. 5th International Conference on Electronic Participation (ePart), Sep 2013, Koblenz, Germany. pp.57-68, ⟨10.1007/978-3-642-40346-0_6⟩. ⟨hal-01491231⟩
168 Consultations
238 Téléchargements
