Authentication with Time Features for Keystroke Dynamics on Touchscreens - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthias Trojahn
  • Fonction : Auteur
  • PersonId : 1004371
Florian Arndt
  • Fonction : Auteur
  • PersonId : 1004372
Keystroke authentication is a well known method to secure the mobile devices. Especially, the increasing amount of personal and sensitive data stored on these devices makes a secure authentication system necessary. Traditional security techniques like the four-digit PIN-input are insufficient and do not correspond to the present password standards. A keystroke behavior based authentication system could increase the security. Different researches have been published based on keystroke authentication systems with traditional PC keypads. But the keystroke behavior on touchscreens, as they are nowadays used on smartphones, are not analysed before.
978-3-642-40779-6_17_Chapter.pdf (500.49 Ko) Télécharger le fichier
hal-01492821 , version 1 (20-03-2017)
Paternité
Matthias Trojahn, Florian Arndt, Frank Ortmeier. Authentication with Time Features for Keystroke Dynamics on Touchscreens. 14th International Conference on Communications and Multimedia Security (CMS), Sep 2013, Magdeburg,, Germany. pp.197-199, ⟨10.1007/978-3-642-40779-6_17⟩. ⟨hal-01492821⟩
696 Consultations
133 Téléchargements
